Signs101.com
Go Back   Signs101.com > SOFTWARE • Open to All Members > Corel
Notices
Corel CorelDraw • Photopaint • Corel Trace • Plug ins
Main Menu
Module Jump:
September 2010
S M T W T F S
      1 2 3 4
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30
Signs 101 Merchant Member Directory
User's Login
User Name
Password
Remember Me?
Mini Stats
Members 15,861 Entries 0
Members Entries
Threads 67,494 Reviews 0
Threads Reviews
Posts 740,799 Polls 198
Posts Polls
Content 16 Files 8
Content Files
Links 481 Ads 0
Links Ads
More...
  #1
Old 02-05-2010, 04:23 PM
Sherry2006 Sherry2006 is offline
College Freshman
Fountain fill = thousands of lines??
I am using Corel Draw 10 (old, I no lol). Ive been using it for the past 3 years at the company i'm at now. Ive noticed that some of the files (ones that were created by the previous graphic artist) open strange. For example, if there was a circle with a regular fountain-fill effect from black to red, the fill is broken down into THOUSANDS of tiny lines. each line is one solid color, but no two lines are the same color because the circle fades from black to red. Not all images are like this; as a matter of fact ive never had a file do this when I create/save it. Was it a certain setting the previous graphic artist might have applied to the image to do this? Or is it a problem with Corel?
Thanks!
  #2
Old 02-05-2010, 04:25 PM
neato's Avatar
neato neato is offline
Master of Arts
Location: Grand Haven, Michigan and Chicxulub, Yucatαn, Mexico
When an EPS file is created, gradient fills turn into a multitude of solid objects. My guess is the designer before was designing in another program and importing EPS files into Corel.
__________________
Phillip Newell
  #3
Old 02-08-2010, 11:20 AM
Tony McD Tony McD is offline
College Freshman
Hi Sherry.....Phillip is right on.
If this is a file you will use occasionally, you can fix it in Corel and it will stay fixed.
Open the file in Corel, and recreate the circle over top of the original broken gradient.
Delete all the broken parts, and add the gradient to your new circle. Save the file
as a Corel file.
The file will be right when you open it next time.
  #4
Old 02-08-2010, 09:37 PM
Jackpine's Avatar
Jackpine Jackpine is offline
PhD
I use x3 but this will work in 10 also. Make a shape (circle, square ect.) a bit larger than your vector. Create the gradient in that shape and convert it to a bitmap. I use RGB 150 full print size. Then power clip it into your vector and you will have a smooth printing gradient. Works for me every time.
  #5
Old 03-04-2010, 11:41 AM
54warrior 54warrior is offline
College Sophomore
Quote:
Can someone please explain 'power clip' for me?
  #6
Old 03-04-2010, 11:48 AM
jhilldesigns's Avatar
jhilldesigns jhilldesigns is offline
PhD
it takes a vector shape in corel and clips a bitmap into it, making an "alpha channel" of sorts...its easier if you change the default option to not "always center image in power clip"
in tools - options - workspace - edit
__________________
"If this is what you mean by normal, I'm glad I stepped over the line."
-Stratford Mercenaries
  #7
Old 03-04-2010, 12:25 PM
signmeup's Avatar
signmeup signmeup is offline
I never thought of that. That will be a big help when I send my corel files to my printer who uses Illustrator. No more "million circles" for gradients. Thanks.
  #8
Old 03-04-2010, 12:53 PM
bob's Avatar
bob bob is offline
PhD
Quote:
Originally Posted by jhilldesigns View Post
it takes a vector shape in corel and clips a bitmap into it...
Not just a bitmap, any object or group can be the subject of a power clip.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
All Content Copyright © 2003 to 2010 Signs101.com. All rights reserved
TERMS AND CONDITIONS OF USE
All posts and other information available at Signs 101 should be viewed as the opinion only of the poster. No claim is made that any information is accurate. As such, each reader should not rely on any information available here as accurate and should independently verify such accuracy. In addition, no claim is made that posts made here will be free from profanity, obscenity, rude, hurtful, libelous or insulting opinions of the poster. Such posts should, however, be reported to an Administrator for review.
Neither the owners, employees, officers nor directors of Signs 101 shall be held responsible or liable under any legal theory for any loss or injury resulting from any post, information made available, policy, action or lack of an action at Signs 101. Your use of this website is your acceptance of these terms and conditions of use.
