After cutting, reset blade to left position
MangoPRI
Hi all,
After the CJV30-160 has finished cutting the blade stays on the right hand side, how do I send it back to the left without turning machine off and on?
Thanks in advance! :)
Chris
GaSouthpaw
Ours starts and finishes on the "right" side (when you're facing it). Only thing I could suggest is changing your origin to the left side.
MangoPRI
Mine starts in the left, cuts and then stops on the right which is strange, unless process isn't somehow completing properly
Neil
Not sure if you know this, but:
When in cut mode it stays on the right, in print mode it parks the cutter head on the left.
If you want to move it out of the way, press heater/cutter button, then head retract.
Press the down arrow again and you can also turn off the heaters
