Changing Default Contour Color
Discussion in 'Corel' started by LUV DEM TIGERS, Feb 3, 2017.
  1. LUV DEM TIGERS
    LUV DEM TIGERS Member
    206
    Jun 13, 2008
    Irmo, SC
    Is there a way to change the default contour color? I have almost 100 numbers I have to do. They are two colors I create the numbers using a truetype font, change them to the color I want, I add a 2 color contour (of course the first color is what I want but the second color is just assigned), I break all the contours individually, I outline them with my "contour cut", and then I add a contour so I will have bleed. The issue that I have is that the default is 50% of the contour color. Is there any way to change the default to be 100% of my color. I have to go into each one and move the slider bar over to 100%. When you have almost 100 numbers it takes a lot of time.
    Also if anyone knows of other steps I can change to reduce what I already do I would like to know them also. Breaking 100 contour groups and changing the outside color 100 times takes a lot of time.
  2. GraphicsSource
    GraphicsSource Member
    46
    1
    8
    May 28, 2015
    west columbia, sc
    What design software and rip are you using?
  3. LUV DEM TIGERS
    206
    Jun 13, 2008
    Irmo, SC
    Roland Versaworks
  4. myront
    myront Active Member
    503
    29
    28
    Dec 3, 2015
    Niceville, FL
    select your shape/text. click on the contour tool. select the color desired from the drop down then go tools/save settings as default
  5. VanderJ
    VanderJ Take two Dampers and Call me in the Morning
    1,784
    87
    48
    Aug 2, 2011
    Denver, CO
    If you are using Illustrator to design, just select one of the lines you want to change the color of. Then go to the, "Select" menu and choose "Same > Stroke Color" Now all of them are selected and you can change the color whatever you want. If you are using other software, they all have something similar, just look it up on Google.
  6. myront
    503
    29
    28
    Dec 3, 2015
    Niceville, FL
    Lets expand on this. After thoroughly reading your first post I see your dilemma. Ensure that your outline color is the the same as your contour outline color. Then save settings as default. Another thing to do is after setting all these parameters save the preset by clicking on the the "+" next to Presets. Give it a unique name.
Similar Threads - Changing Default Contour
  1. Jim Hill
    3
    159
  2. K2
    7
    233
  3. stickerman12
    4
    210
  4. chad17
    3
    202
  5. Bcrawf
    3
    154
