Suggestions Cut vinyl for floors
Discussion in 'Product and Supplier Referrals' started by bigben, Jun 5, 2017.
  1. bigben
    bigben Moderator Staff Member
    1,231
    14
    38
    Sep 3, 2007
    Quebec
    Is there any cut vinyl that is ''rated'' for floors? I've got a customer that want dark grey lines on his floor. If there is no such products, what alternative would you recommend? Paint is not an option.
    Thanks.
  2. GaSouthpaw
    GaSouthpaw Premium Subscriber
    614
    105
    43
    Dec 1, 2005
    Georgia
    I don't think (not 100% certain) any of the vinyls for plotter cutting are going to hold up to traffic without laminating them- which will lead the customer to expect you to replace them for free when they fail.
    With a laminate made for that application, though, I'd think just about any high performance vinyl would work if properly applied.
  3. Devon19515
    Devon19515 Member
    57
    5
    8
    Jan 12, 2015
    Georgia
    Alumigraphics.
    • Like Like x 2
  4. ikarasu
    ikarasu Member
    301
    64
    28
    Jun 10, 2016
    Port Coquitlam, bc
    Product Catalogue: 3M™ 3645 Floor Overlaminate
    This is what we use. Just used it on some 180, in a very high traffic 10-20,000 people per day area. It's been up a few months, and no signs of peeling yet. We've used it in the past... but I haven't been back to where we applied it, been a few years and we haven't had to re-do it, so I'm presuming it's still good.
    I'd say go with a high-tac vinyl, then overlam it, and it probably wont go anywhere. If they're a warehouse, and you have forklifts / pallet jacks riding into it a lot, Not too sure how well it'd hold up... Ask your rep for a sample, put it down and let it sit a few days / week, see how it's doing.
    • Like Like x 1
  5. What type of floor surface?
    On concrete I have sealed the surface with a good quality paving sealer, I used Feast Watson here in Aus. Then apply a quality cut vinyl, i have done it with both 7725 and Avery 900. Then reseal with 2 coats of the same sealer. I have used this in an area that has vehicles and trolleys.
  6. ams
    ams Very Active Member
    1,019
    34
    48
    Oct 28, 2010
    Virginia
    They make special vinyl for floors, make sure it's anti-slip. To my knowledge, they don't make a cut vinyl for it, so just get the printable one and print the gray.
  7. RJPW
    RJPW Major Contributor
    10,077
    75
    48
    Oct 24, 2007
    Canada
    Also FYI most of Avery's overlaminates are UL classified for slip resistance so you may not have to go out and buy the expensive "floor" laminate.
    NetSuite | Page Not Found
  8. Billct2
    Billct2 Major Contributor
    6,128
    129
    63
    Mar 12, 2005
    New England
    You might try searching for Warehouse/Safety striping suppliers. Just not sure they'll have the color you want. Other than that using a gray vinyl with the correct ant slip laminate would work best.
