Software Help Cutting software
Daveg123
Hi everyone. I have been using Cut Studio with geat success but what software can I use that can cut any type of font not just truetype font as in Roland Cut Studio
Any suggestions
Greatly appreciated
WildWestDesigns
If you have Ai or Corel, there is a Cut Studio plugin for both of those. Just convert fonts to outlines and send to Cut Studio. Or, you can bypass Cut Studio with using Ai or Draw as well, as long as you have the drivers for your cutter.
Only downside with cutting direct from Ai or Draw, is that it cuts in order of layer hierarchy, which depending on the design, may not be the most efficient cut path.
Could always try Inkscape as well, same con as above though.
