Flexi won't print images with contour cuts..
Andy D
I had been using Flexi all day, no issues, and then it stopped sending prints that have contour cuts to
production... the cut file is sent but not the print file. It will send print files that don't have contour cuts.
Any suggestions?
eahicks
You have it set to "Contour Job only" in your Rip and Print settings. If there's no cut lines it will still send a print job.
Andy D
Thanks, that was it.
My Flexi seems to revert back to old settings on it's own for some reason,
do you have the same issue?
Joe House
There's job info that retains the settings from the last time the job was sent. It shouldn't do this on a new job unless your default job settings for the printer, in production manager, are set that way.
jayhawksigns
Always hate opening an old job and forgetting to check my settings before I print/cut. One big reason I disabled remote send in Production Manager a while back.
pholt1
Sometimes our Flexi goes haywire when printing and cutting vinyl. I usually have to close the software and reopen.
