Need Help Help! Wrap sizing gets cutoff when design is in versaworks
Discussion in 'General Chit-Chat' started by Jonzed, Jul 13, 2017.
  1. Jonzed
    Jonzed Member
    31
    Jan 15, 2017
    Tennessee
    I have a wrap design that is 278 inches. When i import pdf or jpeg in to versa works it cuts length to only 200 inches. How do I fix this?[​IMG]
    Sent from my SM-G955U using Tapatalk
  2. Joe House
    Joe House Member
    180
    28
    28
    Feb 5, 2004
    WA
    You may have to scale it down to 50% before you save the file then scale it up 200% in VersaWorks.
  3. iam808
    iam808 New Member
    19
    1
    3
    Feb 15, 2012
    east
    The problem is with the .PDF and not Versaworks. If you open the .PDF and hover the mouse around the bottom left hand corner the document size will appear and it will read 200"x 33.5".
    Downsize the file and republish to .PDF or just go with .EPS
  4. Jonzed
    Jonzed Member
    31
    Jan 15, 2017
    Tennessee
    But if I downsize the file the design will be smaller correct?
  5. Joe House
    Joe House Member
    180
    28
    28
    Feb 5, 2004
    WA
    Which is why you would scale it back up to 200% in the RIP.
  6. crystalcoastgraphics
    crystalcoastgraphics Member
    334
    13
    18
    Sep 30, 2011
    North Carolina
    Is it raster? If so save as a tiff. Will print fine.
  7. shoresigns
    shoresigns Active Member
    689
    23
    18
    Nov 1, 2011
    Vancouver, BC
    200 inches is the standard limit for PDF files. Apparently Corel ignores these standards, making it easy to create PDF files that are incompatible with other software, such as VersaWorks.
  8. CL Visual
    CL Visual New Member
    6
    Jun 8, 2016
    Copiague, NY
    I've had this issue with PDF's in Versaworks. I do a lot of box truck wraps and they're usually about 300" wide. Now if I have a PDF, I bring into photoshop and flatten the file and save as a TIF. Shouldn't have an issue after that.
    I think the problem is that the PDF actually holds a lot more than what is visible and it puts it way out of bounds for versaworks acceptance.
