How to fix corrupt powerpoint file?
I have a Powerpoint pptx presentation which reports and error when I attempt to open it. The system may have been turned off in the middle of a PowerPoint session. The file was a pptx file from a later version of PowerPoint. I loaded into a 2007 version and it still came up with an error but offered to repair which it did. I saved the repaired version to the old format for use with PowerPoint 2003.
What is good software for PowerPoint file recovery?
allen.welch
Before going the route of purchasing software, make sure you can't recover it using the built in file repair process. Have you tried the built in file repair process? It is an option when you use the file open dialogue box, there should be a drop down on the Open button that has Open and Repair.
Also, there were bad updates recently that causes files to become corrupt. They may be salvageable -- which version of PPT are you using?
If the problem still persists, then check your file through an online service.https://onlinefilerepair.com/en/powerpoint-repair-online.html
If it turns out that it is damaged then I as an expert can advise you to use the utility PPTX Repair Kit to repair a damaged file. I wish you success! http://www.pptx.repair/
There are many software vendors in the market which provide you recovery tools for corrupt PowerPoint file. Most of them are available with demo/trial version for free evaluation. So before you can purchase any such paid software, you must download free demo/trial version. By using demo/trial version, you can see what you can actually recover from the corrupt PowerPoint files before you can pay for the software. If you're satisfied with the results, you can purchase the software to save the recovered data into a new PowerPoint file.
Or if you're looking for free solution, you should try the manual tricks shared in this article - Repair PowerPoint Presentations with Easy Manual Tricks
The manual tricks shared in the above blog post can help you fix corrupt PowerPoint files without using any 3rd party tool. I hope the shared information would be helpful here.
Regards.
