Pricing Standstill With Project- Need Some Feedback
what the
Owner/op
I am second guess the estimated value of a painted sign- Attached is the scale and metal siding-
The rendering on the wall isn't accurate but the - It should show much larger- But use as a reference only for a feel of work...
I don't want to under or overcut- I was thinking 8,000 +. ? Alot of friggen work- lift is supplied.
What would you suggest in fair market (California)
Sam I Am
Painted many of these buildings, but I'm in Alabama.
Think about your pricing. Two areas at 1000 sq. ft. No way to paint these easily on corogated metal. 2 Colors as well.
Do you consider $4.00 a sq. ft. enough?
what the
Owner/op
hmmm. I shouldn't shoot myself- I'll aim high and leave up to them to reduce the size or removed 2 colors
Do you consider
Don't know where you're getting your sizes ??
I'm coming up with he's getting about $10.5 a sq ft price. That's about 750 sq ft based upon what I'm seeing.
However, I would advise against the thin white outline. That will be a total waste. Not hard to do, once the black is on, but still a gross waste and effort.
edit : Oops, think I'm wrong. More like about $6.00 a sq ft I was off by one zero.
Rick
Looks like a total of 1710 square feet to me...
That makes it 4.69 a square foot.
Having seen a big high school mural go bad on new corrugated, I would be worried about the paint not holding up and having to redo it... I would factor a little into the price
  • scaled painting.pdf
Sam I Am
Gino, In his original post he stated that both lines he had figured at 10' high by 100' in length. ( X 2 ) is where my cipherin' came into play. Seems like it's been edited out of the original post.
In the drawings the lower black panel scales at 10' x 100' + / - Upper Copy looks to be maybe closer to a 8' height on Caps, 7' on smaller Caps, + / - x 95' When I quote, I try to make sure if I err, it is in my favor...
Next time, I'll quote the post so it'll still be there.
