What techniques do you guys use to cut perforated vinyl without it messing up on edges?
0igo
So this question is mostly for car windows that have a rubber edge trim around the windows, where you cant easily glide the blade along it, how do you guys cut perforated vinyl without cutting the rubber?
Starter
You should cut back from the rubber approx. 1/8" and edge seal the perf with 8519 or edge sealer.
papabud
Lone Wolf
when i have window perf i cut it 1 of 2 ways. a good tuck and edge cut or i have a little metal washer i put the knife into and it glides along making a uniform cut
Dan360
I tend to just use my finger(s) between the knife and frame as a spacer. Might not be the safest, but I find it easier to adjust for width and faster than reaching for another tool.
shoresigns
This is what I do. Just brace your fingers on the edge of the window wherever you can, and cut carefully. Takes a bit of practice. Try one of those mini snap-blade knives—I find them much easier to hold steady and cut straight than an X-acto, which just wobbles all over the place.
S'N'S
It also pays to use stainless blades so you don't scratch the window. If your a bit heavy handed a standard blade will scratch where you cut on the glass.
0igo
I'm trying to picture the washer but can't lol. Could you post a picture sometime?
