X5: Toggle wireframe/enhanced?
Colin
I assigned F9 a s a shortcut key to go from "enhanced" View mode to "wireframe" (something I do a lot), but can we get it to toggle back & forth between enhanced & wireframe with that same shortcut key? It seems to want to be assigned another key to go back to enhanced.
oldgoatroper
Roper of Goats. Old ones.
I set mine to Ctrl-Shift-W for wireframe and Ctrl-Shift-E for enhanced. Almost as good, I think...
WildWestDesigns
I don't think you can with the same key. In Ai you can, I set up a button on my Cintiq to do that, but based on how the options are presented in the drop down menu for Corel, I don't think that you are able to do that with the same keystroke.
SignManiac
I haven't run across any way of using the same key either. I use alt+P all the time for power clipping and set up the hot key, alt+E to extract. Nowhere did I find any info for toggling the same key to reverse a function. Maybe you should tell Corel about it and they can include that in a future update?
Colin
Dang. Ok, thanks for the replies. Funny how my 13 year old ScanVec Inspire will toggle on the F9 key for wireframe/color.
oldgoatroper
Download this macro:
http://macromonster.com/index.php?mod=descr&id_desc=63&keyword=toggle+wireframe&Submit=Go
Unzip it
Open this path:
C:\Program Files (x86)\Corel\CorelDRAW Graphics Suite X5\Draw\GMS
(if your draw is installed in the default directory)
Drag the gms file from the zip to this directory
Then go to:
Tools > Customization > Commands > Macros > shortcut Keys
Assign the macro to F9
Toggle away
wayne k
guam usa
The macro certainly seems cool... but why is it needed?
In X3 and I imagine 4 and 5 as well there is a command called Toggle View (default key is Shift-F9) that toggles between wireframe and enhanced.
All I did was switch Keyboard shortcut with the Full Screen Preview command (F9).
<edit> yes, this works in X5, as well...
GAC05
Quit buggin' me
Good catch - learn something new in Draw every day..
wayne k
guam usa
Colin
Hmmm, Ok, I did it that way and deleted the Macro. I couldn't find the "Toggle View" in any list, but I found the little "search" icon and typed it in, and found it. F9 now toggling!
Thanks guys!
