Need Help 1" pvc question
Cynosure
Hope this is the correct area, but what is the preferred method for attaching French clear type clips to 1" off for exterior mounting? I assume it's more then just "screw them in". Is there a particular molly/adhesive to use? Any input is appreciated!
visual800
heres my 2 cents on 1" PVC. Its thick and its heavy I will NOT install any of this stuff without going thru the face of this material UNLESS it is small then I will install studs thru the back with silicone
Johnny Best
If your making the french cleats out of pvc you can use PVC cement that you can purchase at homedepot with some countersunk screws that are the right size so as not to go through to face.
And yes, 1" thick PVC is heavy, unless it is a small sign.
