1204 Head Fuse keeps blowing
Hi Guys,
I have a very confusing problem here, my vj1204 magenta ink line that goes to the damper had a slight leak, once i changed that line the head fuse on the main board blew, now every time i change the fuse and power up the machine the fuse keeps blowing, what could be causing this,
Need Help URGENTLY,
Thanks,
G.D
kffernandez
there is obviously a short. you could check if the cables are ok and are properly seated, and make sure that the electronics of the head doesn't have any ink drips.
henryp
Your printhead could be faulty and is causing the fuse to blow, possibly needs replacing at this stage.
