Question 50 50's how would you make them?
Tony McD
I have a customer wanting me to quote a quantity of 50 die cut numbers.
They want the number "50" hooked together so they are one piece.
It is their 50th anniversary so they will be shiny gold. The will paint them if
necessary...maybe even use some glitter.
These are for a "one day" event, so it doesn't matter what they are made of
as long as they last a day..lol.
They will be hanging on the back of each chair for one day and probably tossed.
Could be cardboard or thin plastic, etc...something a little rigid.
Total size, in the neighborhood of 12" x 12"
They usually want quality stuff and don't mind paying the price, but this time
they want as cheap as possible.
Any ideas on how to produce these?
wes70
You could use some .020 styrene. Stack together and cut out with jigsaw, scrollsaw or bandsaw.
Sent from my Nexus 5 using Tapatalk
Christian @ 2CT Media
Do 16 or 18pt cardstock, we make part masks and etc on this all the time.
Billct2
I don't know what equipment you have, but if it was me I'd be subbing it out to someone with a flatbed router and doing it on something like polystyrene. Have them printed gold and then they can add glitter.
Modern Ink Signs
Pick you vinyl metallic, chrome or other gold color
Apply to styrene, pvc or your choice of material
Take to some with a CNC router and presto. 50s you have!
You do have a relationship with some with a cnc router right!?
Tony McD
Thank you for the ideas.
I have a roland versacamm and a vinyl cutter, no access to a router or laser.
Will look through the my list of wholesalers to see if any have the ability to do this.
DerbyCitySignGuy
I'd buy these (or something similar) and then sell them to the customer at a markup. More hassle than it's worth for something that the customer could buy online if they spent 30 seconds on Google. That's just me though.
[Edit: Apparently the link doesn't work, but you get the gist. Google 50 glitter cutout and find something that works.]
d fleming
Thin styrene coated with gold metallic vinyl. Small sheets cut down to easily run through your plotter. Crank up the pressure and score the sheet as good as you can. Snap out the 50's and smooth edges where necessary. Put new blade in plotter.
