64 Bit system works fine with cutter
Hi I have a mimaki CG-75FX using Win 7 64 bit. Works fine no problem at all with mimaki drivers and finecut 8 for both corel and adobe. I am using a serial connection on mine and not USB if that helps. BTW serial is much better for distance. USB should be kept under 2m unless you add a powered hub. Don not use USB extender cables! Been there, done that, troubleshot a seemingly obscure problem as a result. All drivers (latest) and FC8 was downloaded from mimaki website.
