News A detailed introduction to the T0-T10 status of the aluminum plate
Discussion in 'Vendor Shout Out' started by guojianbin, Sep 26, 2020.
  1. guojianbin
    guojianbin New Member
    T state is one of the five main states of aluminum plates, and the T state of the 6 series aluminum plates has the most products. T state represents that the state of the aluminum plate has reached a stable state after heat treatment. According to different aging and different processing techniques, the T state is subdivided into many subdivision states, which represents that the aluminum plate has different properties. Here is an introduction to the T0-T10 aluminum temper chart status:
    T0 state: After solution heat treatment, natural aging and cold working state. It is suitable for products whose strength is improved by cold processing.
    T1 state: Cooled by high temperature molding process, and then naturally aged to a basically stable state. It is suitable for products that are no longer cold processed (straightening and leveling can be carried out, but the mechanical performance limit is not affected) after being cooled by the high-temperature forming process.
    T2 state: Cooled by the high-temperature molding process, and naturally aged to a basically stable state after cold working. It is suitable for products that undergo cold processing, straightening, and leveling to increase strength after being cooled by a high-temperature forming process.
    T3 state: cold working after solution heat treatment, and then natural aging to a basically stable state, suitable for cold working or straightening after solution heat treatment. Products that are leveled to increase strength.
    T4 state: After solution heat treatment, it is naturally aged to a basically stable state. It is suitable for products that do not undergo cold processing (straightening and leveling, but without affecting the limit of mechanical properties) after solution heat treatment.
    T5 state: The state is cooled by the high-temperature molding process and then artificially aged. It is suitable for products that are artificially aged after being cooled by the high-temperature forming process without cold working (straightening and leveling can be carried out, but the mechanical performance limit is not affected).
    T6 state: the state of artificial aging after solution heat treatment. It is suitable for products that are not subjected to cold working (straightening and leveling can be carried out, but the mechanical performance limit is not affected) after solution heat treatment.
    T7 state: similar to T6.
    T8 state: the state of being cold worked after solution heat treatment and then artificially aged. It is suitable for products that have been cold processed, or straightened or leveled to increase strength.
    T9 state: artificial aging after solution heat treatment, and then cold working state. It is suitable for products whose strength is improved by cold processing.
    T10 state: After being cooled by the high-temperature molding process, it is cold worked and then artificially aged. It is suitable for products that have been cold processed, or straightened or leveled to increase strength.
    What is solution heat treatment? Solution heat treatment refers to the process of heating the alloy to a high-temperature single-phase zone to maintain a constant temperature, so that the intermediate phase is fully dissolved into the solid solution and then rapidly cooled to obtain a saturated solid solution.
    What is natural aging? Natural aging refers to placing the workpiece under natural conditions such as outdoors, so that the internal stress of the workpiece is naturally released and the residual stress is eliminated or reduced.
    What is artificial aging? Artificial aging refers to heating the workpiece to a certain temperature, and then cooling it in the furnace or in the air after holding it for a long time (5-20 hours). Compared with natural aging, it saves time and the residual stress is removed more thoroughly, but compared with natural aging, the force release is not complete.
    • Like Like x 1
  2. James Burke
    James Burke Being a grandpa is more fun than working
    3,431
    459
    83
    Jan 2, 2010
    Mitten State
    But this doesn't settle the pronunciation of the word. I love how the Brits call it "Al-yoo-min-eee-ummm". Perhaps it comes from spending too long in the "la-bore-uh-tree".
    JB
Similar Threads - detailed introduction T10
  1. Blackhawk11
    1
    468
