ACM 8 x 12 ft Sign
mameighan
Client wants 8 x 12 ft acm sign. So I normally just get 4 x 8 printed from merchant here. They can print to edge. If I layout my design in flexi how do I cut into 3 images for printing and then do we just align the seams after printing? (client will actually be doing the install).
I know with vinyl you would probably do an overlap but not with ACM - right?
Any other suggestions before I take this on?
And if you don't mind where would you be on pricing for the print only?
Mark
bannertime
Easy way is to mask 4x8 panels and export in your favorite flavor of file type. No overlap. Make sure to explain to your printer that they are butt seam and that the panels should line up.
