Need Help Acrylic letters mounted with spacers
Chillyredfox
Hi everyone!
Newbie to installs and looking for advice on drywall installing
I have 8 letters in 1/2 inch acrylic about 7 inch high. Mounting them to an interior drywall wall which will have a moss wall feature. The letters need spacers as it needs to be 1.5 in - 2.5 in from the wall to either clear the moss or possibly inset snug with moss (undecided yet)
My question is I see installs with Molly type anchors to the drywall with studs but then how do they screw in to the back of the acrylic when you screwed to the anchor already.
I see people that use a threaded back acrylic to then add spacer and set with silicone through the wall without an anchor. Is that correct standard?
Basically I’m confused at the best way to secure
Thank you all so much for any advice!
Ryze Signs
Usually we install flat cut outs just as you described. Studs are threaded into tapped acrylic letters, or attached with glue pads. Then we drill the hole pattern in the drywall add the spacer (usually a piece of 1/4 or 3/8 PEX tubing) then silicone the stud in the hole.
2.5 inches is a pretty long standoff. Could you possibly mount all the letters to a backplate that screws to the wall then gets covered by the moss?
Chillyredfox
Thanks for your reply! The length of the stand off I am a bit worried about - agreed. I believe I can provide a mounting template to the moss guys so it could be possible to do a back plate. Sorry to ask but how does the mounting plate work with securing to the letters?
Thanks again!
signbrad
Setting studs into holes with silicone to hold them is industry standard. A typical stud length is three inches, which normally allows sufficient penetration into the wall. If you feel that, in your case, a penetration of 1" or 1-1/2" is not sufficient, use a stud longer than three inches.
Gemeni, Inc., sells studs in various lengths.
2-1/2" from the wall is a somewhat long standoff, but not unheard of. You could run nuts onto the ends of the studs, stopping them 2-1/2" from the back of the letters. The nuts could serve as "stops" at the wall surface, helping to prevent the letters from sagging. I have installed letters this way with a standoff of four inches from the wall.
There is rarely a need for any kind of "anchor" on the end of a stud.
Brad in Kansas City
Evan Gillette
Agreed, if needed you can also run painters tape from the face of each letter up to the wall as temporary support while the silicone sets up but usually not needed as long as your holes arent sloppy.
Chillyredfox
Brad in Kansas City
Thanks Brad!
The nut idea is smart ….. they won’t see what’s behind the letter due to the moss so I think that’s a great idea! Thanks for the tips!
Ryze Signs
Thanks again!
I was thinking the plate would have countersunk screws going through the back into the letters. You would have to mount your letters first and the moss guy would have to work around your letters which may not work for him.
