Question Any reccomendations for ink configuration of Oce 480 GT
gmarshall
We are purchasing a used Oce 480 GT and we are wondering if we should configure our ink as CMYKLcLmWhWh or CMYKCMWhWh? Any reccomendations?
MrRu
It's really going to depend on what applications you are planning to print the most. If you intend to do a ton of fine art then probably the CMYKLcLmWW but if you are doing mainly production then the later option would likely be a better option for you. We have a an Oce 460GT with CMYKWV but do mostly production work so we rarely ever use the varnish so we should probably convert it to CMYKWW. What ink set are you planning to run? IJ256 or IJ258?
