Anyone had problems with Triangle inks?
Discussion in 'Roland' started by enes, Jan 21, 2020.
  1. enes
    enes New Member
    11
    Jul 5, 2017
    cazin
    Hi guys
    In march 2018 I bought a new roland rf640. Version with double cmyk....after about 3 months of printing it just started loosing blue nozzle than black and so on. A few cleanings would cure the issue but it would do the same thing repeatedly .
    My roland techitian left a epson SC so I can continue working and they could not fix the problem so they gave me a brand new RF640 2 months ago.
    Again with the new RF theese last few days the machine is doing the same loss of nozzles as the previous one
    Only after medium or a powerfull clean I can print a few meters and again it looses cyan .... magenta
    With the first and the new RF we are using Triangle inks . Double cmyk .... no head strikes . And i regulary look after the machine
    My techitian has no clue ...
    Nozzle test photos attached
      File size:
      75.1 KB
      76
      File size:
      108.6 KB
      75
      File size:
      151.3 KB
      71
  2. Gene@mpls
    Gene@mpls Very Active Member
    2,029
    111
    63
    Jun 17, 2003
    Blaine, Mn
    We are on our 2nd RF and have never used anything but RXV bulk system, not a problem in 5years. Ten years before that with bulk Triangle on 3 Rolands and no issues at all.
  3. hazartilirot
    hazartilirot Member
    85
    7
    8
    Sep 23, 2018
    Ukraine
    Well, Once I wanted to use triangle inks but then as I read reviews of customer I decided to switch to Afford 707.
    Many customers say that triangle might be used under the following condition if one doesn't stop printing 24/7. Otherwise the print head would have the same problem as you have mentioned.
    I suggest you change inks to something else... like Marabu or Nutec.
  4. hand851
    hand851 Roland Mutoh & Mimaki inks digiprint-parts.com
    197
    17
    18
    Nov 22, 2010
    Columbus, Ohio
    Change cap tops and do a cap adjust. are you putting cleaning solution in the caps weekly?
  5. enes
    enes New Member
    11
    Jul 5, 2017
    cazin
    Since the machine is only a few months old , we didn't change cap top or dampers ...
    Seems its some kind of roland production error
    On the first machine that had the same issues they tried replacing dampers captop and even the printhead and the problem was still there
    We're currently waiting for another technitian to take a look , I'll post it here if they find a solution
  6. iPrintStuff
    iPrintStuff Prints stuff
    1,100
    317
    83
    Sep 3, 2018
    United Kingdom
    What’s the actual system like? Our first mimaki system had inks exposed to the air (lid over, loosely sealed) and we had intermittent magenta drop outs. Switched to an ink system that had the vacuum bags and haven’t had a problem since.
  7. enes
    enes New Member
    11
    Jul 5, 2017
    cazin
    Not ciss system but Regular ink cartridges (440ml.) , double CMYK like standard cartridges
