Click to Support Signs101 ...
Hi. Just wondering if anyone has applied Avery 1105 on awning material? A scrim type of awning. Wondering how well it will hold up. Would there be a better option for printable vinyl other than the 1106?
If you're putting it on something like panaflex, just make sure the surface is EXCEPTIONALLY clean. If it's a new face, you'll be fine, but again, make sure it's clean.
Will this be backlit? If so make sure you evaluate the print in the same conditions.
You might want to use a translucent or transparent film. If not the 1105 should work fine.
