Avery 1105 wrap vinyl on awning
donkur
Hi. Just wondering if anyone has applied Avery 1105 on awning material? A scrim type of awning. Wondering how well it will hold up. Would there be a better option for printable vinyl other than the 1106?
Johnny Best
By scrim you must be saying it is a vinyl awning. Do not know about Avery vinyls but try a test on material. A good cast vinyl should stick.
jcskikus
Owner, Designer & Installer
If you're putting it on something like panaflex, just make sure the surface is EXCEPTIONALLY clean. If it's a new face, you'll be fine, but again, make sure it's clean.
Joe House
Sign Equipment Technician
Will this be backlit? If so make sure you evaluate the print in the same conditions.
You might want to use a translucent or transparent film. If not the 1105 should work fine.
Geneva Olson
Expert Storyteller
I'm just curious. How do you backlight an awning? isn't it jutting out of a building?
unclebun
