Bad Encoder strip. Can I still cut?
Goatshaver
My encoder strip on my SP-540V is definitely bad. Can I still cut jobs that I've already printed??
On that same machine..... I doubt it, unless you're thinking about doing it by hand.
If your print was printed askew, I highly doubt your cutter will do the same, in the same fashion. Your registration marks won't line up to where the prints are now located. Besides, anything printed with a bad strip or eye, probably isn't worth trying to salvage, anyway. Type machine doesn't really matter, this is basic encoder 101.
And yes,literally cut them by hand while holding and guiding a knife of some sort. :covereyes:
Goatshaver
They were printed before the strip was bad.
I didn't know if it just used the crop mark sensor and data from the file for position. Guess I'll just have to wait for the new strip.
Give it some time. It's only been less than an hour since you first asked. Maybe someone who knows for sure will chime in for you. We have the same machine, but never had anything sitting around so long after the strip went by to experiment with. Why not try one and see ??
Goatshaver
Ok So cutting is unaffected as long as the printing and marks are good.
I can print uni-direction, but the print and cut marks print with bi-direction and they get slurred. Anyway to get around that? haha
And who is a reputable supplier I can get this from without waiting 3 weeks like I did with digiprint.
Goatshaver
Have you tried flipping the encoder?
Just my .02
I have not. Can you enlighten me on this...specifically which way to I flip it?
Sorry as I'm learning to service this machine because Roland doesn't support it anymore and I def. cannot afford a tech.
GTSTech_1
It requires you to remove the encoder (Remove the spring side 1st), once its' out then you will need to attach the bracket that was on the left to the rightside, make sure the bottom of the encoder is now the top when returning the encoder to it's home.
