Best laminate for UV inks?
Brian27
We're looking for a new laminate to put over ridged substrates printed on an Oce UV Flatbed. We've been using a mactac polycarbonate because it has an extremely strong adhesion but it's just getting too expensive. Something like $800/roll.
Can anyone recommend a clear laminate that resists abrasion and has good adhesion to UV inks?
WYLDGFI
What is the primary purpose of the laminate? Simply to provide UV or as an anti-graffiti shield coating??? We use Briteline UV lam all the time on our agfa. but our UV inks run thin in comparison to others. Our AGL Laminator runs at 120° or thereabouts and we get little to no silvering and such.
Norman Clifton
We have good luck with Rite-Media Gloss Laminate RM-STL3-54-CG its low cost
https://www.allgraphicsuppliesusa.c...onal-gloss-laminate-54in-x150ft-rm-stl3-54-cg
we print on UCJV300
Brian27
Thanks for all the suggestions. I'll look into these ones so far.
We use it to protect logos for displays against water/moisture and people using cleaning products to wipe them down. Indoor only. Once we apply it to the print, which is on acrylic, we cut the print to size on a miter saw. So, the adhesion has to be awesome or else it will tear up at the edges.
99% of the time they're printed with a black background so it's extra tricky getting them perfect with no debris or imperfections.
