Click to Support Signs101 ...
it's a toss up, you need a low tack that will stay up and also won't remove paint when removed.
first even with low tack the longer its on the surface it starts to become more permanent (bonds more aggressively )
and if you get something that is not aggressive enough it will start to curl or come off as you get temp changes.
how long does the material need to be up?
we have used the orafol 3268 and 3628 for event graphics that need to be removed but they are usually up for 5-8 hours
worst case one day and they remove ok
