Best printer for...
SameDay Signs
Trying to get some opinions on a good but mid price printer that can mass produce full color signs...we run mimaki in house but am looking at maybe a flat bed but I have a friend who is dye subbing 1000s of signs and honestly it just seems like it's to costly and time consuming but looki g for opinions on it. It's a thin tin/aluminum type of material I would using to print on
Thabks in advance
printguyjohn
Get a flat bed HP Scitex on Global garage for less than $20k, have a tech inspect and install, and you should save a ton of money with a great machine
Global Garage Dot Com has many units available, it's where I purchased mine
BigfishDM
Thabks in advance
They are probably using the Chromalux dye sub metal panels and they look AMAZING!! You can get into Dye sub for fairly cheap but you will need a good heat press to go with it.
