Suggestions Bronze plaque on chain link fence
Chuck Peterson
Does anyone ave a good way to install a 5x10" bronze plaque on a chain link fence? I'm trying to avoid S hooks. I'm thinking a metal plate the size of the plaque on the back side of the fence, with nuts on the studs, but then I have the ends of the studs sticking out.
Any suggestions?
Thanks.
Billct2
I would do a plate on the back, thru bolt, cut the excess bolt off and file down. Then put a cut across the bolt/nut (unless you use one way nuts) and cover with dab of construction adhesive.
MikePro
we've done both, pull plate of metal on backside or top/bottom 1-2" strips of 1/8" alum, with tamper"proof" countersunk screws tapped into backside of the plaque. ...although "tamper proof" is only as good as one's ability to obtain a wire cutter and run off with a nice piece of metal with fencing attached, but at least we're making them work for it.
