Can't save file in EPS format
Team Valhalla
Customer sent us an image as a PDF. I am able to import it into Coral X7, manipulate it, change colors, and apply a contour cut line.
When I try and export it and save it as an EPS file.... Coral shuts down.
I can save it as a jpeg and PDF... but not an EPS file.
Is there possibly some sort of security "thingy bob" in the original PDF file?
Any insight would be appreciated.
Thanks,
SP
Stormyj
Just another guy
There maybe something in the file causing it to fail when trying to convert. Try selecting the entire object and converting it to an object. Then try exporting it. Not sure that it will work, but worth a try.
knucklehead
Mine did that one time. Reset Corel, F8 when Corel is starting, then proceed. Worked for me. Thanks to a member here, who let me in on that little trick.
Team Valhalla
Stormyj.... I used the "convert to curves" option and it worked!
Knucklehead... just for grins and giggles, I'll try that too.
Thanks for the input!
SP
boxerbay
I have found on some rare occasions if i hit copy all - open a new document - then paste it in it works fine.
Team Valhalla
Boxerbay... I've had that situation in the past also - didn't work this time though for some reason.
Knucklehead... F8 key pounding... no difference, still didn't work.
As I mentioned, I did get it to work by converting it to curves. I'll have to remember that one down the road.
SP
