channel letter stitcher (
VIPUL PATEL
We have studied about channel letter stitcher. We are looking to buy it to reduce production costs.
After looking online, we found about Accu Clinch and SDS stitcher.
Which one do you all recommend?
Does anyone know any cheaper but good quality machine?
Bradley D
www.jigsign.com
The best Clincher is the Norlok. https://norlok.com/product/letterlok/ I wouldn't buy anything from Computerized Cutters. The advantage of a clincher is that they don't use consumables. But they are a little slow and putting in the wrong gauge of material can break the machine.
Stitchers have a more even playing field. The SDS Automation, Ideal Stitcher company, or Bosch are all solid machines. I'd recommend purchasing stainless steel wire even though it is more expensive than galvanized. The advantage of a stitcher is that you can use aluminum composite panel. The stitchers are also super fast. Just watch your fingers.
If you want to go super cheap, I've seen sign companies use pneumatic staplers from home depot or lowes. Not sure what the UL inspector would say about that....
