Need Help Cjv30-130 Pr 181 Error
Start the machine in service mode by holding remote and function while powering on. Once it boots up, push the function button and then scroll up until you see the [HASHTAG]#Parameter[/HASHTAG] menu. Hit enter and then scroll down until you see the, Cut System Parameter menu. Hit enter and then scroll down until you see parameter # 37. Set that parameter to 0. Let the printer finish updating the parameter and then completely power down the machine by switching off the back power switch. Wait about a minute and then power back on in normal mode. The machine will turn on and re-calibrate the lock position automatically and that should fix your issue.
kayhan
thank you for you help, to day i try what you told me when i hit 0 on the # 37 it doesnt make any calibrating after i reboot the machine
