CNC / Laser cut pieces needed
BrianKE
I am looking for 10 pieces of 24" x 24" .080 Aluminum (white) cut to match the attached image. My regular supplier is only able to cut 3 out of a 4' x 8' sheet because they need about 1/2" for the CNC machining. I am looking for someone that can CNC these from a 5' x 10' sheet or maybe cut them from a 4' x 8' sheet using a laser.
These signs are to match some existing signs so I am unable to simply reduce the size of the sign to fit to 4' x 8' (the signs need to be 24" x 24" overall).
TIA
Brian
  • 190917.pdf
Greg Kelm
www.cheetaprint.com
reach out to sendcutsend.com and oshcut.com They might not have white, but powder coating is inexpensive. What they can fit on a sheet is on them and they might even utilize the remnant for other things.
