Converting t-shirt conveyor dryer to UV curing
csc
Hello all, It's been a long time since I did any screen printing. But now I want to get back in but don't have the room to add a UV conveyor dryer to do up to 24" wide UV printed signs. Has anyone heard or know of anyone converting their std. conveyor dryer to UV? I believe I have plenty of room in my dryer to install UV lamps, I just have to install proper ventilation. Thanks for your input.
Bill Modzel
It may be doable but it won't be inexpensive. I think I saw a convertible ad on maybe 15 years ago. I'd just google UV reactor manufacturers and go from there.
thewood
Aw, when I read the partial title of this thread I hoped it would be about converting a t-shirt conveyor to a pizza oven.
:thread
Mosh
Buying a used one will be cheaper, easier, and you know it is going to work. I have never owned a UV print system, but know people who have them. Neat stuff, who would think light can cure ink that fast.
csc
I know that that are used UV dryers out there but I don't have room to add another conveyor. I can easily remove the heater assembly off my t-shirt conveyor in under5 minutes.
That is why I question use of a UV unit to use on my existing t-shirt dryer. Thanks for the feedback.
G-Artist
UV lamps are an animal of a different breed.
Expensive and they require special handling...like never, ever, touch them without an ultra-clean gloved finger.
There are a few companies that can provide you with retrofit kits. You'd still need to invest in a UV Radiometer to get accurate measurements...not cheap.
I am not trying to hijack this thread but since UV is the topic I'd like to ask if anyone knows if sunlight, which contains the ENTIRE UV spectrum, is suitable for a full cure of UV ink printed material be it screen process printed or digital printed?
csc
Thanks for the reply, you know, you might have a point. If one can burn a screen using the sun, then why would it not be possible if properly timed, but then then once exposed to the sun I don't see how over exposing would be bad since they will be outdoors anyway. Just a thought. I once had sample uv inks and gave them away since I was not equiped to cure UV. I will ask around or even go to a commercial printer and see if he can spare a small amount to test.
