Corel X 7 Question about Selecting Colors
Discussion in 'Corel' started by LUV DEM TIGERS, Oct 12, 2018.
  1. LUV DEM TIGERS
    LUV DEM TIGERS Member
    284
    7
    18
    Jun 13, 2008
    Irmo, SC
    I have a vector woodgrain pattern that I would like to change the colors on. It currently consist of 6 colors. I know I can set all day and click on all of the same shade holding shift and then change the color. But is there any way that I can automatically select of the same color by just a click or two? There are literally thousands of pieces that make up this woodgrain vector pattern.
  2. myront
    myront CorelDRAW is best
    1,027
    175
    63
    Dec 3, 2015
    Niceville, FL
    take a look at this free macro
    many more macros available too.
  3. myront
    1,027
    175
    63
    Dec 3, 2015
    Niceville, FL
    You can also go Edit/Find and Replace/find objects then step through all the particulars you want to find
  4. Solventinkjet
    Solventinkjet Merchant Member
    3,370
    575
    113
    Aug 2, 2011
    Denver, CO
    In Illustrator all you do is select the object that is the color you want to select and then go to the select menu and choose, select same fill color and it will select all of the same color. But that won't convince you Corel users and your macros. ;)
  5. neato
    neato Very Active Member
    2,126
    272
    83
    May 16, 2003
    Henderson, IL
    Use the color syles docker. (ctrl + F6)
  6. LUV DEM TIGERS
    284
    7
    18
    Jun 13, 2008
    Irmo, SC
    I will try some of these other suggestions but I did find that you can do Ctrl +F and you can find the fill colors and replace it with another.
