Need Help Cut force is not consistent
bastropsigns
Im die-cutting stickers, and the last 6-10 inches of the sheet my force seems to drop because I cant pop the stickers out like the rest of them. I have replaced, cutting strip, blade, blade holder, cut carriage cable and guides, cutter solenoid, carried board and servo board.
SlikGRFX
I assume you are using a print+cut machine? If so it's probably temperature related. The vinyl at the end of the cut job could be slightly colder.
Try cutting at a lower temperature but with slightly more pressure for more consistent results.
MBO_1
Is ther actually a cutting line viewable ? I always put marks (just a few pixels to print) outside the whole area where the machine has to cut. Otherwise (i suppose a software error) some areas are not always cut...
