Cut Mylar with a CE5000?
GP
Need to make a couple of stencils - anyone try cutting mylar with their graphtec?
Gregg
CS-SignSupply-TT
First, make sure the mylar has a backer. If none, use app tape as your backer. Second, Graphtec RED TIP bladeholder with 60 degree blade. Third, pretty obvious, test the blade depth. Finally, you probably want to slow the cutter down.
