Cutting ACM... the right way, the cleanest way...
Patentagosse
I'm more big rigs lettering / graphics oriented but like other shops, I don't turn my back on smaller projects when asked by long time customers. I'm getting more & more requests for small signs made of 3mm ACM (call it DiBond, AluPanel, whatever...). Most of the time I cut 'em with my X-Acto and snap 'em on the edge of my table, rub a rod along the sharp edges to smooth 'em (or sand block). For bigger panels (4x4 or 2x8) or bigger projects (quantity) I use my bench saw but it throws chips / chunks / debris everywhere in my installation bay so 'forces me to vacuum the whole floorspace (...). Also, as I don't have "receiving tables" all-around the bench saw, it's kinda difficult to cut a full sheet in (2) 2ft by 8ft pieces by myself (one-man-shop) and anyway cuts are razor-sharp so they still need to be smoothed.
My question (sorry for the long intro): are the ACM cutters like Keen's SteelTrak ST-250 worth the investment? Durability? I like the factory-like rounded edges they make... Could maybe saves me time on the long run.
Give me your inputs / opinions please
Johnny Best
Track saw and hook up your vacuum hose to it. Cuts a nice edge which does not need sanding. Very precise and accurate cutting.
Hardly any cleanup.
FatCat
Yup, we have a Dewalt track saw and it virtually cuts all materials in our shop - PVC, dibond, acrylic, coro, anything. And its always straight and always a factory finish on the edge. *Just purchases a 4x8 CNC table, so will be able to do more intricate stuff with that, can't wait!
shoresigns
X-Acto knives are for cutting paper and vinyl. Try a scoring knife instead:
When we're cutting more than 5 feet, we'll use our panel saw. We only clean up once in a while, as it's out in the middle of the bays and it generally doesn't go that far. For most cuts, we use the Fletcher and it does a splendid job on anything up to 6mm. Ours has a laser built in it for making sure you're going straight, but that never seems to be an issue.
If we have lotsa blanks needing to be cut, we'll have our vendor do it. It only holds the whole order up by one day. Totally worth it.
DerbyCitySignGuy
Guillotines and shears are nice in my experience. They leave a really nice edge that doesn't require any finishing. Track saws and panel saws are a close second. Especially if you have a nice one. Minimal edge finishing if you have an appropriate blade for your saw. More versatility from track and panel saws too (especially track saws, everyone should have one).
Sign.ed
We use our track saw for any volume, but don't have orders with enough quantities to ask our vendor to do it. We do have a shear so anything less than 3' we cut on that.
burgmurk
I use a steeltrak, and it's not terrible. 3mm ACM cuts well, but 4mm can be a struggle, depending on brand. It's fantastic for corflute and foamcore type materials, but those are easily cut on much more simple and cheaper devices.
I'd get a track saw if it were my choice. they're more versatile, and with the right blade you can cut v-grooves and make boxes. In theory the steeltrak can do this with an extra attachment, but i personally wouldn't trust it to do a good job, having used it for straight cuts for 9 months it just doesn't feel 'solid' enough.
