cutting paper on a plotter HELP
fastmax
we are trying to cut snowflake style designs out of paper, i have not had success on our laser doing this, next try is seeing if i can get the plotter to cut it, its a graphtec
any tips tricks would be awesome
thanks
WhiskeyDreamer
Professional Snow Ninja
I wouldn't suggest it as the pieces will jam up as the falls out come out. Is hand cutting an option? Otherwise, you should find someone that can die cut them.
J Hill Designs
a long time ago we did this with thick construction paper - masked it with low tack transfer, cut the non-masked side JUST enough to allow them to pop out
johnnysigns
Thin styrene may work also, but you'll likely have to strip the parts out and that may not be feasible with a complicated design.
Zac
Mediocre Designer
This. You may want 2 layers of application tape just for the extra thickness, this is how I used to cut .020 styrene on a CNC router. Same principal though.
bob
Unless you have a lifetime supply of blades the last thing you ever want to do is cut paper on a plotter with a blade designed to cut vinyl. Paper is incredibly abrasive and will take the tip off a plotter blade is short order. Since it's the tip that does the cutting, the blade is now dull.
