Cutting shapes in 10mm corrugated plastic
wjstewart
Anyone have some suggestions on an easy way to do this?? Router and jigsaw have been melting the edges. This is workable, it just requires a lot of clean up. Trying to work smarter, not harder. Thanks.
wjstewart
Thanks for the replies. I'm off to get a metal cutting blade and give it a try.
For a better idea of what I'm cutting it's a 30"x35" sign with an arched top and a starfish poking off one side. I've got a ton of these to do, and was thinking about making a template out of thick max-metal and routing the edges. Tried routing and it makes more mess than it's worth.
Update. Just jigged two and they turned out fine, only a little clean up. Takes some time though, about 25 min on each.
mark galoob
try a pair of electric or air shears...i have used these on 10mm coro and its like cutting paper...very easy
mark galoob
johnnysigns
I'm cutting thinner coro on a gerber router and it's coming out excellent. Typestries was nice enough to make a post ages ago about speeding up the feed rate and slowing down the cutting rpm for good results. I'm running 400 ipm at 10,500 rpms on 4-5mm coro w/ excellent results.
Maxphobia
Zune flatbed cutter large machine and costly but it pays for itself pretty quickly and can be used to cut shapes out of many different types of substrates
MikePro
stack em' square and cut all at once with a bandsaw. not too much melting that a scotchbrite pad can't cure.
