Directory Signs - Exterior, Quality Solutions
rdm01
Hello,
I recently installed some fabricated steel lettering for a client, and they would now like to add a directory beneath it. The client has several buildings, and will later want to add similar directories to each building. At first I had recommended aluminum plaques mounted to the wall with laser cut acrylic lettering that can be changed out if needed (would only be changed if entire departments moved), however they want to see something a little different.
Is there a prefabricated system that someone has used that they would recommend? Possibly something that can come in a few different sizes for the larger and smaller buildings?
Thanks!
