Doing a die cut on my Mimaki CJV30-160 in FlexiSign10
Look for the half cut settings on your machine and voila. But it will kill your knife and cutting strip pretty quickly. Check it out and i'll give you some tips to improve the technique if you like the results.
thesignxpert
if im using flexisign pro and sent to print and then cut it after the printing since i dont laminate the decals do i set up before it goes in to cut mode?
You need to set your machine to half-cut on the printer itself from its own menu and then just send the regular cut job from the computer. No matter what program u use you PRINTER receives the data and makes it normal cut or half cut.
