Door cover error
Recently changed printhead in Mutoh vj1624 and put back together and powered on to get door cover er
  • Mutoh
    Votes: 0 0.0%
  • Forum
    Votes: 0 0.0%
  • Total voters
Steenland
Old Member
I'm not familiar with your printer specifically, but I've had this issue with an HP Designjet. The cover wasn't in alignment with the switch that indicates that the cover is closed.
Look for a part on the cover that pokes in, and that should help you locate the switch. Press the switch. If it now indicates that the cover is closed, it is probably an alignment issue. If it still indicates that the cover is open, there may be a problem with the switch itself, or its wiring.
I agree with above. Also make sure the maintenance doors are shut. They are finicky and can look closed when they aren't!
