Dr Stika - Foison C34
ianmeets
Hi, I have an SX-15 running with Dr Stika. Its got a problem (see my other post) so I invested in a new Foison C34.
The software recommended with it seems really poor (SignBlazer Elements) so I'd be keen to carry on using DR Stika. The problem is I can't get Dr Stika to find the C34 as the drivers are poor so it doesn't show up as a 'printer'.
Having set the C34 up on comms port 4 etc is there any way I could make it appear in my printer list?
Many thanks for your help,
Cheers Ian
Techman
comm port is not a printer port. IF that machine needs a printer port then you may be out of luck.
There is a way to send printer commands via a serial port but its stakes some gyrations that users most cannot do.
The problem is.. very few have experience with a stika or the other machine you have.
blackicefx
I've used a Stika-15 with Dr. Stika for quite some time. I finally upgraded to a 40" VE Panter. However, I had tried to play with the Dr. Stika program on other machines. I have yet to find a successful combination. I think you may be out of luck. I'd switch to Corel with SignTools3.
Matthew
BlackIceFX
ianmeets
Hmm, sounds like a pain then. Thanks for your help, pitty no decent drivers came with the C34! So using this comms port theres no way I can add the cutter to my printer list correct?
Cheers Ian
