Drawing out Yellow ink
artbot
??? as in, it's not coming down the line? you cap that line is either not sealing (if you pull at the waste line can you hear air?) or the pump is clogged to that head. (are you running CMYKx2 or lmlc?) or... do you need to know how to get to the ink fill up function?
jaly723
test draw
I did a test draw and it shows about 3/4 of yellow ink. THe rest of the inks are showing just fine. I am running CMYK. Its a JV3 - 160. I am just wondering which lines I need to draw ink from. I realize it should be the yellow ink line. I tried to draw ink and could not get anything so I dont think I have a real tight fit on my syringe.
