Need Help Dry Erease laminate wrinkles over time
Discussion in 'Installation Equipment & Techniques' started by Andrea_neon, Dec 8, 2020.
  1. Andrea_neon
    Andrea_neon New Member
    4
    Dec 4, 2020
    Mexico
    Help! We make a lot of personalized whiteboards by printing the graphics in HP latex 335 and then laminating with Dry Erease laminate 111 from General Formulations. The problem is that 1 out of 3 whiteboards get wrinkles over time, we often use steel or pvc as the rigid material underneath. Mostly the whiteboards are in offices or production sites so they get no direct sunlight.
    Someone knows if we are doing something wrong? is it the laminate? Here's a photo upload_2020-12-8_17-47-6.png
  2. RaymondLoewy
    RaymondLoewy Pretty fly for a Sign Guy
    If you are using Gator board and non-plastic board, you may be experiencing air being blocked by the polyester dry erase OL not being able to "breath"
  3. CanuckSigns
    CanuckSigns Very Active Member
    3,517
    431
    83
    Nov 11, 2008
    Ontario
    I had this happen when prints are rolled up after laminating, I had about 50 feet of prints to laminate with dry erase, when I took them off the take up roll on our laminator they were all garbage. My supplier got a very angry phone call from me that day!
    I switched to a dry erase laminate from drytac and it fixed the issue. I believe the film we had issues with was a general formulations film as well.
    • Like Like x 1
  4. Andrea_neon
    4
    Dec 4, 2020
    Mexico
    Thanks! I'll try with the Drytac, I'm tired and frustrated of throwing all the work away because of wrinkles :S
  5. Andrea_neon
    4
    Dec 4, 2020
    Mexico
    I'm using plastic boards and sometimes steel sheet, that's why I don't understand whats going on. Everything seems fine when we deliver and a few weeks later we get the call....
  6. Zendavor Signs
    Zendavor Signs Member
    263
    41
    28
    Mar 3, 2011
    Peoria, IL
    I'm not familiar with the 111 laminate, but we had that problem a number of years ago using the real thin cheap looking dry erase laminates. Since switching to Avery anti graffiti, we have never had a problem. It is quite a bit more expensive though.
