Eco Sol Max Black Ink Scratching
shoxite
Hello guys,
I have a project that I am doing on Phototex and it is printed only in black. It's basically a kids car road, and kids can use cars on it and this would be used on tables. I printed a sample for the customer and let this thing dry for over a week. When the customer received it, she said that there are scratches all over the roads after only 20 minutes of play. I am using Eco Sol Max inks and realized this with other materials that the ink (black mostly) scratches off easily, even after leaving it a week to cure.
Roland recommended to upgrade the firmware and upgrade to Eco Sol Max 2 as it's more scratch resistant. Any thoughts? Would love some advice.
Thanks guys,
Eddie
jfiscus
Rap Master
I would try printing with a different machine/ink if your prints are scratching. You could try a very light spray coat of liquid laminate since this is phototex.
Eco solvent will not resist more no matter what you do. Polyester needs sublimation ink to be permanent. Sublimation changes the color of the fabric itself just like if it was waved with colored thread. (you should probably outsource this one)
flyplainsdrifta
+1for an overlaminate or vinyl or outsource. you're gonna have a hard time with sustained abuse on phototex. highly suggest using a floor overlam, i actually did this on a table for a buddy with the floor laminate and it took abuse of 3 kids over 2 years. pretty solid.
premiercolour
Hello guys,
Thanks guys,
Eddie
We have customers who had same problem. So we advised to change from Eco Solvent to Mild solvent ink. We have Jetbest compatible ink for Mimaki SS21, which both printers share the same Epson printhead technology. With SS21 mild solvent in Roland printer, print will be much more scratch resistance. No flush, just three strong cleans and you are good to test / go.
More information 949 209 7306 or sales@premiercolour.com
Francis
AKwrapguy
Hello guys,
Thanks guys,
Eddie
Doers it have to be onto Phototex? Also if you know someone with a latex that has gen 3 inks they are scratch resistance.
mleg1972
Francis
Greetings Francis, it's Melvin. I'll be calling you soon about the flourescent dye sub inks.
Sent from my Moto Z (2) using Tapatalk
