Econo-corr sign install
Discussion in 'Installation Equipment & Techniques' started by L Town Graphics, Jun 1, 2012.
  1. L Town Graphics
    L Town Graphics Member
    57
    Making a 2'x6' sign for a customer. It is being installed to a Local little leagues main building. The building is wood sided (more or less a large shed). I was wondering how the pros would install this sign? This is my first one so any help would b appreciated.
  2. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    15
    screws. 1/4 turn back from tight, pilot holes larger than screw bore
  3. L Town Graphics
    57
    That's easy enough! Thanks.
  4. Gino
    Gino Premium Subscriber
    31,106
    1,645
    113
    Jun 7, 2006
    PA
    You might want to use a washer with that screw, so it doesn't pull through.
    Quick question,,,, why worry about mounting something permanent, when you're using the cheapest and least durable substrate other than paper in the industry ?? Why not step up your game and use something longer lasting, unless this is gonna be taken down at the end of the season, which in that case, just mount it on a post or something and not put holes in a wall for something temporary ??
  5. 2B
    2B Moderator
    2,708
    289
    83
    May 5, 2011
    TX
    +1
  6. L Town Graphics
    57
    what type of substrate would you suggest? its going on the building because thats where the space is provided
  7. Gino
    31,106
    1,645
    113
    Jun 7, 2006
    PA
    To make a professional job, I'd use aluminum composite for starters.
    Heck, even a banner would be a better choice than Cor-X...............
  8. john1
    john1 Guest
    I know fields around here use polystyrene sheets each year. Works great to be honest.
  9. J Hill Designs
    15,549
    15
    econo core is alum composite gino.
  10. J Hill Designs
    15,549
    15
    actually it kinda looks like corrX with an aluminum skin..
  11. Gino
    31,106
    1,645
    113
    Jun 7, 2006
    PA
    Sorry, my bad. :doh: I thought it stood for economy corraplast. In that case, stay with what ya got, L'town.
  12. L Town Graphics
    57
    if im correct (dont hold me to it) it is a single sided alumacorr. by single sided i mean only one side has a alum face.... not double sided. On that note install? predrilled, screws and washers?
  13. 2B
    2B Moderator
    2,708
    289
    83
    May 5, 2011
    TX
    Read it the same as Gino,
    predrilled is not required but does make it easier
    make sure your washers are large enough to cover flutes and dont over tighten the screw or will collapse the material.
  14. L Town Graphics
    57
    thank you very much sir for the help!
