Empty PNG's in Flexi 10
Anyone had this issue? Create a PNG with no background in PS, save it. in all my viewers the image is there, but when importing into Flexi, it's a blank image. I don't always get this problem though, I use PNG's often for contour cutting right to the image.
Snydo
Try zooming out, that sometimes makes things magically appear.
I find that black and white .PSD are 100% reliable, just slap a bezier on it then contour that.
Best of luck.
Snydo
Use bezier, enchanced corners, or enhanced curves, the latter two have tolerances you can adjust, one of them will get you a perfect contour 99% of the time. Instead of going through the trouble of setting up a transparent background in PS just make it white.
