Envision 375 y axis overload help please
Jase
Just in the middle of a job and the cutter seemed to max out to the left. It is now stuck, says y axis overload if I try to move it to the left I can't move the knife housing to the right either. It literally feels like it is hitting a brick wall as you try to push it to the right. Any suggestions?
We do have a contract but I need to use this machine urgently.
Jason
Jburns
You may want to pull the right side metal black rear cover off, - this is below and behind the keypad. and check belt on the Y axis motor. it may be jammed.
From Manual:
Y Axis Overload Tool head motion moving left
and right Motion is jammed or obstructed.
Solution:
Unjam Y axis. Retry. Call Field Service if retry fails
Jase
Just an update, took the side off and the cog had a very small piece of dirt lodged in it. Quick clean with a toothbrush and all fine, phew. Thank you so much. I was just about to plug in my HS15 backup.
Jase
It was the large gear they drives the belt, should have got a picture. Such a small piece of dirt :(
