Epson dx5 printhead
THATA
Hello. I have a problem with my eco solvent printer. It uses epson dx5 printbead head. When I print nozzle check other colors don't come out. So now I want to clean the head but I only have cleaning solution for Roland. Can I use it to clean epson dx5 printhead?
Ahmed Samy Nagada
You have to use same type of cleaning fluid (ink + cleaning fluid must be compatible) else the different chemistry can cause permanent damage.
Are you sure it's clogged, it can be air in the ink tubes.
ricomuchi123
when i did a manual clean from eco solvent i can see some lines spread side ways. but only the side line of the head.
