Need Help Epson s30670 material bunching
rwinkie
Printed about 5 yards of 54" material (Avery 1105 vinyl). Went to load the next roll and now it's bunching up in the middle after it's been loaded and does its precheck. Everything was going fine with the first roll. Tried a new roll of material same thing. Have adjusted the feed roll so it's feeding strait. Appears the pinch rollers on the left side of the printer could be applying more pressure than the right side causing the bunching. Anyone experience this? Any suggestions on what could be causing one side of the rollers to be applying more pressure?
TIA
unclebun
Do you need to clean adhesive residue from the vinyl path through the machine? That will cause hangups and bunching.
